Subwoofers not working like they should
Discussion in 'Audio, Video & Gadget Tech' started by Kickerking817, Jan 26, 2011.
  1. Kickerking817
    Kickerking817 Rockstar
    Ok guys I'm almost to the breaking point with my subwoofers and or amp. Subwoofers have been working fine for little over a year , and amp has been working fine for almost 6 months on this set up. However the amp is a older kicker amp. So my set up has been 3 kicker DVC L5's on a 1200.1 kicker amp as I said it was all working great together for about 6 months when all of a sudden one day I turn it up a little, sounds decent at low volume then when I turned it up it was like the door speakers were the ones trying to push out all the bass, and door speakers started to distort. The door speakers are not hooked up to any amp at all. I checked the amp and noticed the fan on the amp was not working at all, the amp also does not go into protect just not very loud. Like I said I have run out of ideas so any help would be GREAT!! Thanks
  2. jbjones240
    jbjones240 Rockstar 100 Posts
    You might what to check and see what frequencys you are sending to the subs. The amp should have an adjustment as well as the headunit. It sounds like your headunit is trying to send to many of the lower frequencys through your mids instead of the subs. Hope this helps
    -JJ
  3. Kickerking817
    Thanks for the response, I will try it this weekend, what frequency do you think I should set the amp on? What frequency should I set on the headunit? Don't know if this has anything to do with what's going on but my RCA wire was giving me some problems because they are very old(4 or 5years old) and cheap. Would getting better RCA's fix this?
  4. ntbush83
    Actually if I remember right I was having that problem too one time and had to get new RCA wires. Actually I was impatient and made my own but that will cause you major problems. But I also agree about the frequency. Your frequency should really be turned almost all the way down or towards the lowest frequency since you just have subs hooked up to your amp. If none of this works I would try a new amp.
  5. Kickerking817
    Anyone else have any other ideas?
  6. TexasEdition
    TexasEdition Rockstar 3 Years 500 Posts
  7. randomsandwhich
    randomsandwhich Rockstar 3 Years 100 Posts
    I would have to say some setting on the amp got changed.
  8. sstoner911
    You should be able to turn the subs off through your head unit - then you can play your other speakers to see how they sound. If they still distort maybe they are blown or they have to much of the "lows" adjusted to them?
    Are these the stock door speakers running off the head unit?
    If they worked before and all of the sudden you have problems - something changed - either adjustments made via the head unit, something else installed around the time the stopped working correctly or equiptment failure.
  9. Kickerking817
    The door speakers are kicker door speakers, I will try and mess with the settings later and see what happens. Thanks
  10. vncj96
    You can always get bass blockers too for the door speakers, if your amp fan doesnt want to run then I would say something fried on the amp.
