Successful Transmission Rebuild
Discussion in 'GM Powertrain' started by ctys20, Nov 10, 2009.
  1. ctys20
    ctys20 New Member
    I'm just curious, of everyone who has installed a rebuilt transmission what is the success rate like?
    After searching ebay and craigslist there seems to be a lot of hobbyists in the business. I'd thought I'd go the safe route and purchase from a corporation (they have a target if things dont go right).
    Do I just have bad luck or is this just a really complicated part that a lot of people dont get right the first time?
  2. dsquared
    dsquared Member
    Bypass the rebuilds by other companies, you probably will get 1yr warranty at best and it is usually less. Unless you have ever been inside one before you can't appreciate the complexity and potential problems you could have if not done right. Go the GM certa transmission route from the dealer. They are factory rebuilt units warranted for 3 years and 100K miles. I picked up a 4L60E tranny at the dealer for about $1600 and put it in myself and saved the $500 labor to put it in that I was quoted by other shops. The warranty includes labor as well. To cover my potential labor charges in case something goes wrong I had a friend generate a invoice so I would be covered in case it had to be pulled.
  3. Jimmiee
    Ditto on the Serta transmission. You can't beat the warranty and it's good nation wide. Another good choice is Jasper but then you have the third party problem if something goes wrong.
  4. silveradotrailblazer
    If your looking for a stock rebuild than the GM Serta is the way to go.
