Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by L0sts0ul, Apr 8, 2009.
  1. L0sts0ul
    L0sts0ul Rockstar 100 Posts
    Hey guys,
    I Got a 93 burb, completely rebuilt the entire drivetrain about 3 years ago, and put about 50k on it since
    I did so.
    I was wondering if anyone knows of a good kit I could install on this beast, its a 350 with TBI, I love this truck, and its a toss up between the 383 stroker I want, and a blower. I want the blower for reliability, but lets face it... a stroker is.... well a stroke.. nuff said.
    I Want reliability, as this is my daily driver, but I Want more power for hauling my trailer through the mountains, and well... for fun as well.
    thanks a lot
  2. GrandPrix46
    GrandPrix46 New Member
    I was recently checking out some vortech blowers for my '01, the kit was $4500. I think a custom turbo setup would be cheaper than that, and make more power. Unless you can find a used blower setup for cheap (or know someone that can fabricate exhaust piping), you'd probably be better off going aspirated with the 383.
    EDIT: vortech's website is
  3. L0sts0ul
    Ifound a procharger kit with an aftercooler, and a weiand twin screw setup closer to an eaton m90 supercharger like the ones found on grandprix gtps. Both kits come fully ready to install and can be done in 6-12 hours in a shadetree situation.
    both are in the 5k range (CAD) so I dunno what do you think? I honesly could buy a 383 longblock assembly for that much up here and just drop it in.
    I like the reliability of a blower though.
  4. vncj96
    I would go with the stroker, i think you would get better use of power with all the added torque at the low end.
  5. L0sts0ul
    I agree with you about the stroker, however, I live in canada, and its my daily driver... I NEEED it to be reliable..
  6. tbplus10
    Reliability of a blower?
    Have you had a vehicle with a blower before?
    The blower itself may not break a lot (but when they do its catastrophic and usually takes the whole engine)but keeping a forced induction engine running correctly is a pain in the butt, they require constant tweaking and tuning, altitude and weather can make a difference in the way these things run when your pushing them for optimum performance. I have 2 Supercharged trucks right now (99 Tacoma 3.4 with a TRD Blower and 7th injector kit, 97 Suburban 7.4 with a Vortech twin screw blower for sale).
    Add to the cost premium fuel because they hate to run on anything less (Octane additive in the bottle doesnt get the job done).
    If your looking for a tow rig and in town play toy the stroker motor would be a better invesment. A Blower kit runs between $2K and $7K without any ignition add ons or fuel system upgrades. Yes you will gain performance, but your still running that old engine with XXX amount of miles that was just handed a shorter life span, and if you dont get the ignition dialed in correctly and end up with the common problem of spark knock you'll be looking for new heads soon.
    A stroker can be done for under $3K but probably end up closer to $5k, but now you have a freshly rebuilt engine.
    And since youve added all that horsepower you better start saving for a trans rebuild or replacement and some work on the rear diff to upgrade or change it.
  7. GrandPrix46
    What is the compression ratio of your engine? With flat top pistons i'm guessing over 10.0:1? With a CR that high, you're not going to be able to run very much boost. Not sure if 5-6 psi will give you more power than the 383 would, not to mention you will HAVE to run premium fuel, and having some way to tune the fueling/timing of your truck would be a good idea. Do you trust your head gaskets with that much cylinder pressure?
    As far as reliability, GTP's run 200k+ miles easily, and they come non-IC from the factory (albeit with 8.5:1 compression), so a blower is as reliable as anything else as long as the vehicle is tuned properly with no detonation. Anything under 30% throttle = no boost anyways, and I only go above 30% when i'm trying to haul ass, so 90% of the time i'm not in boost.
    In your case i'd go with the 383, i've built plenty of SC 3800's, but if I had the option of going with a 383 V8, i'd go that route in a heartbeat. Get it built with 9.0:1 compression or so, and turbo it later on (when you can afford a built trans and rear).
