Swap 2001 5.3 into 08 Silverado
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by PSIRockin07, Jan 22, 2014.
  1. PSIRockin07
    PSIRockin07 New Member
    Found an 01 5.3L with a wiring harness for $300. Same mileage as my current engine which is a 4.3L. What all would it take to do this swap and have the setup work correctly? Would it cost way more than it's worth of would it be a cheap alternative to buying another truck (which I can't do) or buying an 08 5.3 which is considerably more expensive.
  2. RayVoy
    Are you changing the engine because you have a crack in the exhaust manifold of the 4.3 (earlier post)?
  3. PSIRockin07
    No, I've been wanting to do an engine swap for a while. The cracked manifold just brought the idea to my attention again.
  4. j cat
    if this were a 70's vehicle it would work. with the computer controls on the entire vehicle systems since that time, swapping engines and transmissions is not an easy or cheap way to go for these to work correctly. I am sure it is possible ,but will cost a lot.
  5. TRPLXL2
    If I was doing this swap, I would do it like I did my LS1 swap in my Colorado. I would make it stand alone, which would mean that none of your gauges will work. Your BCM would be untouched, and all of your body controls would function correctly.
    01 is ODB2, and 08 is CAN... This will be your biggest obstacle, anything is possible.
  6. RayVoy
    Just so we don't confuse the issue, The engine diagnostics are still ODB2, CAN (Controller Area Network) is the protocol that is used between the individual computer modules in the newer trucks. It provides a service similar to the LAN (Local Area Network) that we use on our home and office computer networks.
