sway bar end-links
Discussion in 'Lifted & Offroad Suspension' started by K15 Blazer Guy, May 31, 2013.
  1. K15 Blazer Guy
    Im having a hard time finding taller sway bar endlinks... no one includes them in their lift kits... which is retarded
    i got some lift keys for my truck but ive only been able to gain about an inch of lift, because anymore and ill snap another endlink.
    any product links or ideas?
  2. Enkeiavalanche
    Enkeiavalanche Loving the Outdoors 4 Years ROTM Winner 5000 Posts
    Hellwig does have a Adj Sway bar link But you should be able to find a longer link at a GOOD autoparts store..
  3. tbplus10
    Got any welding or fabrication skillzz?
    Or a local shop that might be able to acomplish this?
    Longer swaybar links arent hard to make, lots of times you can even use your existing end pieces and bushings to fab them up.
    The key thing is keeping the swaybar arms level on a horizontal plain.
  4. K15 Blazer Guy
    yeah, i would need to fabricate something... they would need to be well over a foot tall...
    no one makes them that big
  5. Enkeiavalanche
  6. tbplus10
    I was trying to find an example to show you but couldnt find anything, since you wheel your truck you could design an end link that has a quick disconnect so you can remove it when you go off-road to get better articulation from the front end.
  7. K15 Blazer Guy
    ok, now i get what you mean
    i need to combine these
    with these
    and then, replace those bolts with some pins & clips if i want quick disconnects...... easy lol
    i dont wheel much now... i bought the truck and sold my jeep cause the jeep drove like crap... it may have been more manoverable on trails, but it wasnt a nice daily driver...
  8. tbplus10
    Oh this is an easy one.
    Do you have a Tractor supply near you?
    Replace the long shoulder bolts with the washers on them with Lynch pins of the appropriate size that have mouse clips on them.
    Lynch pins are plenty strong their designed to connect tractor accys to the draw bar and can be rated as high as 30,000lbs.
    Something along these lines, you can also place a washer on each end, and if you need them shorter you can redrill the mouseclip hole where you need it. The mouse clip wont be load bearing, only the lynch pin shaft.
  9. K15 Blazer Guy
    sweet! thanks!
    CA ust to be know for agriculture... but.... yeah......... ill hafta get those online i think
    lol
    i could probably buy an illegal firearm quicker than find a tractor supply in southern CA lol
  10. tbplus10
    Yea I lived in Ca. For many years but never learned of Tractor Supply until I moved to Georga.
    Say it aint so, illegal guns in Ca.? Does Di Fi know this?
