Sway Bar
Discussion in 'Lifted & Offroad Suspension' started by jediracer, Nov 30, 2009.
  1. jediracer
    jediracer Rockstar 100 Posts
    My Brother-in-law has a '99 Blazer 4.3L 4WD. He thinks his sway bar needs replaced because his truck drives 'like a boat'. A friend of his said it could be the sway bar bushings and not the sway bar it's self. I offered to help him work on his truck but I not sure where to start and I have a few questions.
    How can I tell if his problem is caused by his sway bar or his sway bar bushings?
    How can you tell if either needs replacing?
    I do not have any knowledge in this area so any input, comments and suggestions are welcome.
    Thanks in advance,
  2. tbplus10
    It's very rare that the swaybar needs replacing, they just dont wear out.
    The bushings and end links on the otherhand do wear out.
    Slide under the truck and look at the bushings, are they cracked or deteriorating?
    Do the end links have any play?
  3. J_chevyman
    J_chevyman Rockstar
    I agree, 95% of the time its the sway bar bushing that go ou, since there made out of rubber...go with the polyurethene ones!!!
  4. jediracer
    Thanks to you both for the info! I haven't looked under the truck myself. I told him to look at the bushings and to let me know what he finds.
  5. silveradotrailblazer
    Has the Blazer always driven like a boat or is this something new. If the sway bars bushings are good than check the front suspension, steering pittman arm, idler arm and upper and lower control arm bushings.
  6. jediracer
    He just told me he wants to replace his shocks as well. We'll check everything out while taking care of the shocks. Thanks for the tip.
  7. jediracer
    New bushings did the trick! Thanks again!
