Tachometer wiring question
Discussion in 'General Chevy & GM Tech Questions' started by BluBurb89, Jul 26, 2010.
  1. BluBurb89
    BluBurb89 Rockstar 100 Posts
    I have an older style 60's Dixco Model 47 tachometer that I want to use. Does anyone know if I need to run a ballast resistor from the HEI coil tach side?
  2. tbplus10
    I dont know if you need to run a ballast resistor but I'm curious as to where you dug that antique up from.
    I thought with the HEI system the voltage was considered to be constant and regulated when the coil was live, which would mean you dont need a ballast resistor in-line, but please dont take my word for it I havent worked on something like that for at least 15 years.
  3. BluBurb89
    At garage sale; it was on the table for $10. It wasn't working; I took it home replaced a resistor, soldered a wire and was good to go on a friends '64 Impala.
  4. Chris Miller
    You don't need a ballast resistor on that 89. It's a computer-regulated system.
