Tail Lights not working!!
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dodger32, Mar 10, 2011.
  1. dodger32
    dodger32 New Member
    i have a 2007 silverado classic, and my brake lights have stopped working. i checked all the fuses and they are all ok. the third brake light still works, and i know its not just bad light bulbs cause the blinker still works. i even tried chaning the bulb to see if just the brake light filament was bad and that did nothing. im thinking it might be the brake switch relay but im not to sure.
  2. stephan
    Your title says tail lights but in your text body it says both brake lights & tail lights. Which are we working with here??
  3. dodger32
    dodger32 New Member
    sorry about that. it is the brake lights that are not working
  4. stephan
    Ok a good place to start would be to have a helper step on the brake pedal while you check for power at the sockets with a volt meter or a test light. Do you know if they both quit working at the same time, or did one go out some time before the other? There has been talk on here about the circuit boards going bad. :-(
  5. dodger32
    dodger32 New Member
    The left went out first then the right
  6. stephan
    OK this sounds like the individual circuit boards then. If this had a common link, they would have both quit at the same time. Go ahead with your power test at the sockets. If no power there, then check for power into the boards. If you have power in, then the boards are bad. This could also be a corrosion problem. Did you see any when you were changing the bulbs out?
  7. pelletman
    pelletman New Member
    Did you fix this? I just lost my brake lights. The third brake light works. Where is the board you are talking about? Anyone know where the wiring diagram is for this?
  8. RayVoy
    If the 3rd works, the brake light switch is good, the main fuse feeding the switch is good.
    You didn't provide vehicle info, but you probably have a fuse for the wires going to the rear light sockets, check it.
    Have you checked the bulbs, like your house lights, it is usually the bulb that goes first.
  9. pelletman
    I'm going to replace both bulbs first thing, but I kinda doubt they would both go out at the same time.. Of course one could have been out for a while.
  10. j cat
    I would hold the brake pedal down [use a piece of wood] then with a meter find the loss of voltage/grounds to the rear brake lamps.
