Tailgate is stuck closed
Discussion in 'Chevy C/K Truck Forum' started by Rlstratton, Feb 18, 2012.
  1. Rlstratton
    Rlstratton New Member
    Tailgate stuck, I have a folding bed cover closed over the top of the bed so I can't get at anything. How can i fix this?
  2. outalne94z71
    outalne94z71 Member
    remove plastic around handle, there are two arm with the rods for the latches under that plastic cover, the handle hinge point of those two arms tends to rust up, you can pry each arm inward to release the gate latches
  3. Jimmeh
    Can you not lift the cover unless the gate is down? If not, you won't be able to remove that plastic cover.
    Had this happen on mine. A few "love taps" with the side of my fist while working the handle and she broke loose. Then you can take the handle off and lube everything up!
