Technical Service Bulletins 2010 Chevy Silverado
Discussion in 'Ask GM Customer Service' started by mkballance, Jul 18, 2011.
  1. mkballance
    mkballance New Member
    I found a website were there are 15 listed Service Bulletins for my 2010 Chevy Silverado. I do my own service, so, how do I get to read the contents of the TSB's. I purchased the service manauals from Helm, but I want to read the TSB's.
    Kent
  2. GM Customer Service
    GM Customer Service Epic Member 5+ Years 500 Posts
    Kent,
    A technical service bulletin (TSB) is the most common type of bulletin: It provides technicians required new service information. It provides a correction to a specific product problem and usually contains repair procedures, information on part numbers and availability, and warranty labor code information. The body of the bulletin will describe the condition, cause, and correction to the problem. These are documents that designed for dealerships, not for customers. If you would like more specific information, I would recommend you contact your local dealer.
    Tricia, GM Customer Service.
  3. sstoner911
    Kent,
    Here you go....
    http://www.aboutautomobile.com/TSB/2010/Chevrolet/Silverado+1500
    Y
    ou can read some of the TSB at that site....it may help or not. Even if you do your own work most of these if not all, are covered by the warranty to the dealer will fix it.
    I did the 1500 model, you can select a different one if you have a 2500 etc....
  4. mkballance
    Thanks for the link.
  5. Nargg
    Nargg Rockstar
    I love this one...
    [TABLE="class: tableTSB"]
    [TR]
    [TD="class: number"]TSB Number: 10-00-89-017C
    [/TD]
    [TD="class: nHTSA"]NHTSA Number: 10038295
    [/TD]
    [TD="class: date"]TSB Date: February 1, 2011
    [/TD]
    [TD="class: add"]Date Added to File: June 14, 2011
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 4"]Failing Component:
    Unknown Or Other
    [/TD]
    [/TR]
    [TR]
    [TD="colspan: 4"]Summary:
    GM: information on fixing multiple situations right the first time.
    [/TD]
    [/TR]
    [/TABLE]
    Just gotta laugh...
  6. sstoner911
    S,ee even GM has a sense of humor!
