Testing Trans Fuse..... Need help!!!
Discussion in 'GM Powertrain' started by Crazycoyote82, Nov 27, 2010.
  1. Crazycoyote82
    Crazycoyote82 New Member
    Some have read my transmission problems and tach issues in my other post. After searching on here a solution could be a bad ignition switch. From what I have read you hook your meter to a ground and the trans fuse. I did this, When the keys are in the ON position but not started yet I get a reading of just under 5 (meter is set at 20V). When I START the burban it wonders a bit. Sometimes it drops to the 2.7 range. I was told this shouldnt drop under 9V. Am I testing it wrong???
  2. Crazycoyote82
