the best parts to add for getting the best mpg when pulling?
Discussion in 'Performance & Fuel' started by chevymon, Apr 26, 2009.
  1. chevymon
    chevymon New Member
    i drive a 2006 2500HD 4x4 and pull a 36 and 32 ft. 5th wheel and other large trailers. ive added a k&n intake, hypertech programmer, and cherrybomb exhaust. what are other afterarket parts that will help increase my mpg?
  2. TheChadders
    TheChadders Member
    lets see
    Electric fans
    full synthetic (oil, transmission, differentials)
    Under drive and over drive pullys
    new spark plug wires with a greater thickness then stock
    waxing your car and using a clay bar will help get rid of drag
  3. chevymon
    chevymon New Member
    what brand of headers works well on an 06 2500HD with the 6.0
  4. Tdaz250
    Tdaz250 Rockstar 100 Posts
    What are pulleys ?
  5. heavy chevy
    heavy chevy Epic Member 5+ Years 500 Posts ROTM Winner
    Get rid of the hypertech and have you a custom tune made strictly for your truck and your mods. This will increase not only your pulling power but you gas mileage also. Off the shelf tuners are made to work on every truck. Custom tunes are made for your truck only. Also what kind of cherrybomb do you have and do you have any sound clips of it.
  6. chevymon
    chevymon New Member
    i have the dual exhaust system. im not sure if theres any more they call it but i busted the welds on the brackets for the pipes out the back so i put turn downs right behind the catiletic converter. y what does the sound clips do for me?
  7. chevymon
    chevymon New Member
    also what company does custom chips or where do you go to get this done?
  8. CarpenterGuy
    CarpenterGuy Epic Member 5+ Years 500 Posts
    google some chip making companies i guess. if you do alot of towing, i'm not completley sure if it'll help gas, but a super charger would help pulling.
  9. FireRed
    FireRed Rockstar 100 Posts
    Look into the under drive pulleys, not a truck story but I feel it has a fair bit of value. I have a boat with a stroker motor, last spring I removed the belt driven sea water pump and installed a crank driven pump. I had to remove my crank shaft under drive pulley, the long and the short it coat me two MPH. Anyone who knows boat will tell you it takes a fair bit of HP for each mile added to top speed, going from a 4-1/2" pulley to a 6" pulley cost me dearly. I am having my under drive pulley machined to accept the crank driven pump to get my ponies back!!!! I am going to put a small pulley on my suburban next!!!
  10. chevkid
    chevkid New Member
    i familiar with cherrybombs, if your looking for mileage or power their not always the best option, an upgrade to a better size exhuast pipe and a muff with proper backpressure (but with low restiction, like a cherrybomb) would probably make a differnce, i think a pipe in the 2 and 3/4 inch range would be a good, set up, maybe go as big as three and a quarter if you plan on many modifications to help tow
