The right battery for a plow truck
Discussion in 'General Chevy & GM Tech Questions' started by Chadlys93Silverado, Aug 3, 2010.
  1. Chadlys93Silverado
    Chadlys93Silverado New Member
    Hey all! I've got a single battery in my silverado, which is set up to plow. When I ran my plow last year, it all but killed the battery when raising the plow. I was told that a second battery was not necessary and that I should look for more cold cranking amps. I've got 800 CCA and that's about the highest I've seen. I think there is more to this. Can anyone help?
  2. silveradotrailblazer
    Well I don't know about plows down here in Alabama, but I use a Optima red battery because my winch killed the stock battery.
  3. hundojoe
    hundojoe Rockstar 100 Posts
    What you need is a 2 battery setup and at least an 180 amp alternator, Thats what would be considered a minimal set up here in Minnesota, but then again some plow guys run there plows for up to 12-14 hours a day on a real bad snow fall and run up to a 250 amp alternator. I dont know how much your really going to be running your plow but any thing more then an hour or 2 puts to much load on a single battery and stock alternator, and even worse if you add extra strob lights.
  4. KyleZ71
    My truck before I bought it was used to push snow. It has the two battery setup. It worked for him so hopefully if you go this way it'd work for you.
  5. murdog94
    X2, and they make a kit if im not mistaken for the Silverado? But i know a few people who just put in a higher output alternator since they dont plow as much (just a few local driveways and mabey their neighbors) so as mentioned alot has to do with your application.
  6. Chadlys93Silverado
    Thanks for all of your input. I guess I'll look into adding a battery and new alternator.
