thottle body spacers and Mass airflow sensors
Discussion in 'Performance & Fuel' started by 03 Black Sunshine, Aug 9, 2009.
  1. 03 Black Sunshine
    03 Black Sunshine Rockstar 100 Posts
    Been looking around and saw a few things that raised an eyebrow or two.
    Mass airflow sensors: claim gains, no real number claim, but gains for hauling, performance and mpg.
    do they work??
    TB spacers: do they work??
    Are either of these worth the money??
    tim
  2. TRPLXL2
    As far as gains go on the MAF I don't think it's any more than 10hp, I had one on my 05' Silverado with the 5.3. I will tell you this if you plan on getting any kind of a tune or chip for your truck don't get the aftermarket MAF, it will interfere with the aftermarket tuner that you get. I had a Granatelli MAF ($300), and then I bought a Hypertech Hyperpac ($500) and the MAF was causing problems with the tuner so I took of the MAF and it let me use the tuner with the stock MAF.
    I have never had a throttle body so I couldn't say, good luck with your choice.
  3. tbplus10
    Mass airflow sensors will usually net gains if you've made other performance mods, bigger injectors, sometimes CAI's, or use a tuner.
    If your thinking of getting a Mass airflow sensor your better off starting with a tuner then add the MAS.
    TB spacers IMO are useless.
  4. Jimmiee
    The MAF sensor measures the airflow as it enters the intake. So how could this sensor give you more performance? I guess the only benifit would be if the OE sensor was sluggish and the aftermarket more responsive. This is what they claim.
    Also if you talk to anyone who has bought one thay will all say they have more power and get 5 mpg better mileage. <G>
  5. 03 Black Sunshine
    okay gang that is the info I was looking for. I sorta figured the TB spacer was useless, I just wanted to ask for your all opinion.
    thanks.
    Tim
  6. 5speedsilverado
    i gained 2 mpg with mine, and it got rid of a dead spot in first, so it was worth it for me
  7. L0sts0ul
    L0sts0ul Rockstar 100 Posts
    imho
    forget the TB spacer, and get a larger throttle body and CAI
    then go to exhaust
  8. 2ToNe04
    yup tbs are garbage
    and the maf will **** your **** up.
    cai and exhaust
    then tune.
  9. 2COR517
    Do you always resort to thinly veiled attempts at profanity to share your thoughts?
  10. Z71_guy
    i believe so
