Throttle Body Port & Polish
Discussion in 'General Chevy & GM Tech Questions' started by chedt713, Feb 4, 2010.
  1. chedt713
    chedt713 New Member
    I wanted to go ahead and polish my throttle body on my 06 silverado...
    I know you need a dremel, sandpaper, aluminum polish..but how exactly should I grind the metal? Should I make a slight taper from the valve to the outer edge? I've been told to leave the valve and the metal directly surrounding it alone, but how far in should I grind? Anyone done this before?
  2. silveradotrailblazer
    throttle body port& polish
    With the bolt-ons you have on your truck you dont need a ported t/body. I went with a t/body velocity stack from Vararam. Its easy to install, just slips into your t/body without removing the t/body just remove the intake tube. It gives you better throttle response that you can feel and is good for 22ft lbs torque in a 5.3 engine. Check em out at It think Jegs has em for $35.00.
