Throttle body spacers?
Discussion in 'Performance & Fuel' started by thekingsphance, Nov 23, 2008.
  1. thekingsphance
    thekingsphance Rockstar
    Hi to all, I've been researching throttle body spacers because it looks like a fairly easy bolt on component. But I can't figure out if they're just a gimmick or if they actually add more HP. Anyone ever tried putting one on? Or know someone who has? Thanks
  2. SoonerSilverado11
    SoonerSilverado11 Rockstar 100 Posts
    You know, I wondered the same thing. From what I hear you do gain a little hp and mileage but hardly noticeable. Then again, some people claim that they notice it, but for the most part people say not to waste your money. But, if you do decide that you want one, make sure you get the helix-bore you don't get that whistling noise. Hope this helps!The Trans-dapt one is the most popular of the people I asked. Also that particular version doesn't get that whistling sound. Unless, you are wanting the whistle. Hope this helps.
  3. ct9a
    From what I understand, the only motors that throttle body spacers make a difference on are the TBI motors. I think this is because it's a vertical style induction system rather than horizontal. Also because the injectors are inside the TB and the stock configuration doesn't allow the cylinders to pull from both, just one. Where as some of the aftermarket one turns that TB into one piece that allows any cylinder to pull from both injectors at the same time making injector matching (which is supposed to be horrible on the TBI motors) less of an issue.
  4. speedfreak391
    speedfreak391 New Member
    I haven't heard alot about tb spacers. But it does look like a good gimmick.
  5. jmonte3
    jmonte3 Rockstar 100 Posts
    i put one on my truck...and i didn't notice all that much...if i had to do it again i wouldn't
  6. thekingsphance
    Thanks guys, I think I've made up my mind. I'm not gonna waste my money.
  7. CoolBlueSS
    CoolBlueSS Rockstar
    I put one on my old 94 with a 5.7 TBI. It improved throttle response quite a bit, and picked up 1.5-2 MPGs. I don't know how well it would work on a CPI or port injection, as the point of entry is not where air/fuel are mixed.
  8. Scott77
    Scott77 Member
    On a TBI it should work just like a carb spacer or a taller manifold. IIRC it widens the power band as well as smoothing the intake flow, could be wrong about that though. I've done it on my carb'd camaros and gotten throttle response and mpg increases as well as a better seat of the pants feel. And since a TBI is really not much more than a glorified electronic carb (works on the same downdraft principles), you should have roughly the same effect. But if you have a TPI or any MPFI you are better served getting a bigger bore throttle body with a smoother intake to make the power.
  9. nikkeshelton
    nikkeshelton Member 2 Years 100 Posts
    SO i TAKE IT THAT PUTTING ONE ON MY 2009 SERRIA WOULD BE A WASTE OF TIME, WAS HOPING FOR A QUICK FIX TO MY ACCELERATION PROBLEM.
  10. Enkeiavalanche
    Enkeiavalanche Loving the Outdoors 4 Years ROTM Winner 5000 Posts
    I never heard anything good about them.. Save your $$$
