throttle body spacers
Discussion in 'Performance & Fuel' started by blakk0nine, Nov 16, 2009.
  1. blakk0nine
    blakk0nine New Member
    Has anyone installed a throttle body spacer? Any noticeable performance / mpg improvement ?
  2. TritonBoulder47
    You won't get any "seat of your pants" HP gains, but you should get some, and you should also gain a little MPG...
  3. ct9a
    A lot of it also depends on what motor you have in your truck. If you type throttle body spacer into the search bar, you'll come up with tons of posts about them.
  4. Kenny
    Kenny New Member
    been using an Airaid spacer for years. Could definitely feel the difference in response (no so concerned with HP). After running it for over a year, i took it out and tested the truck. I'll never do that again.
  5. 2ToNe04
    makes a difference for carb engine
    useless for fuel injected.
    i will paypal you 20 dollars if you gain 1 hp gain on a fuel injected
  6. ct9a
    TBI motors get a benefit as well.
  7. So it does nothing for fuel injected at all?
  8. Kenny
    Kenny New Member
    if your looking for HP increase, not really. Throttle response will be a bit better. The spacer's design is only to "swirl" the intake air allowing the fuel to better atomize and burn more of it. That's why it's threaded in the the bore.
  9. ippielb
    I've noticed a very small increase in fuel mileage, and small increase in off the line, and throttle response, some say it is worth the money, some say it's not, i think it's preference. Don't expect an increase in HP, because if it does, it wont be enough to notice anything.
