Throttle body
Discussion in 'General Chevy & GM Tech Questions' started by 97silverado430, Dec 26, 2008.
  1. 97silverado430
    97silverado430 New Member
    okay me and my buddy tonight put on a throttle body spacer and he was tightening up the bolts and broke one off in the intake manifold. whats the easiest way to get the broke bolt out
  2. tbplus10
    Is it snapped off below the level of the face of the throttle body?
    If not see if you can get a pair of vice grips on it and back it out.
    If it is you'll probably need a set of easy outs and a drill.
  3. henrys021500hd
    henrys021500hd Rockstar
    If it safe to weld in that area, you can weld a nut onto the broken stud and then it should come out. If you have to drill make sure to cover all holes so drilling's don't get into manifold, Henry.
  4. JMoney02
    Welding in this area I would NOT recommend, flammable area, but the vise grips, drill/easyouts and covering for the shaving are good recommendations. If none of these works, which they should. If not, then you will need a new/used intake manifiold and your friend to stay out of the gym. :rofl:
    Keep a decent amount of penetrating oil on the damaged bolts so when your gripping it, it won't heat up so much when being removed...
  5. mrfixdit
    mrfixdit Rockstar 100 Posts
    Often with this small of a bolt a left hand spiral drill bit is all you need. The bolt usually spins out while attempting to drill the hole for the easy out.
