Ticking noise in engine
Discussion in 'GM Powertrain' started by hkinsland, Nov 15, 2009.
  1. hkinsland
    hkinsland New Member
    My wife's 2004 Tahoe has developed a ticking noise in the engine that only occurs between 1500 and 2000 rpms. I put it in neutral with the emergency brake on and ran it up to that range and it still occurs so I popped the hood, had her run up the rpms and it seems to be coming from the top of the engine on the drivers side. It is a metallic ticking noise almost like an old sewing machine. Any ideas as to what this is? The engine has 104k miles on it.
  2. tbplus10
    Possibly lifters, try an oil additive right before the next oil change to clean things up.
    I usually use Marvel Mystery Oil to clean sticky lifters.
    Injectors have been known to give off this sound too. Again an additive in the fuel may help there also.
    Try using a mechanics stethescope to beter isolate the noise.
  3. Kenny
    Kenny New Member
    mine just started doing this, but only when i accelerate, trying to isolate cause..ideas?
  4. Chris Miller
    Lifters. If you've got more than 100K miles, it's to be expected. Kenny, do you have a 350?
  5. Chevyboy96
    Chevyboy96 Rockstar 4 Years ROTM Winner 100 Posts
    Yup sounds like lifters
  6. Kenny
    Kenny New Member
    its a 3.5L...did a obd2 scan...lean condition on both banks as well as 02 sensor 2 low input, and tranny range sensor.
    codes were P0171, P0174, P0332, P0705
    doesnt do it when idle in park when i rev or when cruising, only when slightly giving gas between 1000 to 1500 rpm's.
  7. Chris Miller
    If you're running lean, that's probably causing your ticking noises, then. Change that O2 sensor first, because that can give a bad reading and make the PCM cut down on fuel.
  8. b_burdine
    b_burdine Rockstar 100 Posts
    it's just piston slap... not too much to worry about unless it gets worse
  9. Kenny
    Kenny New Member
    solved it...it was actually the freakin pvc valve. guts were gone. installed a new one and good. guess the guts are now bouncing around in one of the cylinders....:no:
  10. tbplus10
    For your engines sake I hope not. This could lead to some problems.
