Tighten fuel cap light
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Docwilll, Dec 4, 2013.
  1. Docwilll
    Docwilll New Member
    2005 suburban with 310,000 miles. Tighten fuel cap light keeps coming on after cap and emission canister solenoid has been replaced. Any suggestions?
  2. Pikey
    check that the filler neck tube that runs from the tank to the filler neck is properly connected and has tight connections. It could be a tank seal leak also.
  3. Docwilll
    Docwilll New Member
    ok thanks will check.
  4. Pikey
    Did you put a cap on from the dealer or a cap from autozone? Is it a solid cap or one with a key?
  5. Docwilll
    Docwilll New Member
    cap replaced with GM cap, however the solenoid is not it is a Standard brand.
  6. Camaro69car
    Camaro69car Member 2 Years 100 Posts
    sounds like theres a leak somewhere to me. check your connections.
  7. j cat
    what must be done is post the specific DTC failure code. then forum members can direct you.
    could be many different failures from the engine to the fuel fill.
