tighten gas cap warning
Discussion in 'North America - Southeast USA' started by detailjohn, Apr 13, 2009.
  1. detailjohn
    detailjohn Rockstar 100 Posts
    Getting this alarm tighten gas cap, and its tight. Check engine light is on.
    Any ideas?
  2. detailjohn
    06 gmc 4.8l cc 4x4
  3. retired2001
    I know that if the gas cap does not seal, it will throw off the emissions readings. There is probably a sensor that monitors the pres. on the fuel tank. If it is showing a bad reading the CEL might come on. Just a thought. Good luck!
  4. Cableguy
    Cableguy Epic Member 5+ Years ROTM Winner 1000 Posts
    I had that on my buddies 05 Jimmy. Replaced with aftermarket cap...problem fixed
  5. Samplemaven
    Samplemaven New Member
    This just to get my three posts to remove sticky on home page.
  6. 05-Burb
    05-Burb New Member
    Dont buy anything.
    When this tank of gas runs out, buy gas at a different station, then put the gas cap back on as you normally do.
    This should take care of the problem. Usually caused by a bad tank of gas, or the gas cap not put on tightly enough.
  7. Jimmiee
    Bad tank of gas????? Please explain, Thanks.
