    Join Today ~ It's Free
Timing
Discussion in 'Performance & Fuel' started by ejohnson03, Feb 4, 2010.
  1. ejohnson03
    ejohnson03 New Member 1000 Posts
    Timing seems to be off on the 350 TBI in my '94 Silverado.
    What should the initial setting be (0 degrees), with the Computer wire disconnected?
  2. Chad01
    Chad01 New Member
    There should be a placard under the hood somewhere...
  3. Chad01
    Chad01 New Member
    Start engine and bring to normal operating temp. Unplug the base timing connector located in the distributor wiring harness tan wire with a black stripe use a timing light and set timing to 0 degrees at idle. The timing marks are on the crankshaft pulley and a tab on the timing cover with numerical indications... I think this is what you are looking for...
  4. ejohnson03
    Yup... that's it. Set the timing correctly.
    Big difference.:gasp:
