Tinted Tail lights.
Discussion in 'Chevy Truck Accessories' started by ntbush83, Jul 8, 2010.
  1. ntbush83
    What is the best way to get the tinted tail light effect? I know you can by covers or use the spray paint kit or buy a set already professionally tinted. i'm not sure what to go with and what will look the best.
  2. quackman
    quackman New Member
    I used Night Shade, sanded with 2000 grit and sprayed took about 10 minutes per light,if you decide to do it yourself use light even coats, they also make a clear to spray on after you tint but I decided not to do this because I was told the clear would eventually start to crack and peal off!!
  3. HawaiiKid
    HawaiiKid Rockstar 4 Years 500 Posts
    I did the same thing, but I did the clear coat over it and it looks great. The Niteshade is good because if you dont like how dark it is you can always put another coat or two on and make it darker. Easy to do, and def makes the truck look better!
  4. canislupis69
    Get some smoked LED's.
  5. ntbush83
    Alright sweet thanks guys. I know the smoked led's are definitely sick but i'm on a budget so i'll try the night shade. I had looked it up but wasn't sure if it would work but i'll definitely try it out. Thanks
  6. kwalls22
    kwalls22 Rockstar
  7. ZSI52
    If done right the Niteshade paint will work fine and have a gloss look to it. Most people paint with the Niteshades then have a automotive shop spray them with clear. If you take it to the shop and have them done they will most likely put a few drops of black into the clear and spray them.
  8. ntbush83
    tinted taillights.jpg Well I decided to go with the spray tint. three coats of tint and two of clear and this is how it turned out.
  9. ajarman
    That turned out really well!
  10. ntbush83
    thanks! I'm definately happy with the results for the price
