tire size increase
Discussion in 'Wheels & Tires' started by chihawks35, Feb 27, 2013.
  1. chihawks35
    chihawks35 Rockstar 100 Posts
    i have a 2007 silverado 1500 z71 new body syle extended cab with a 2" leveling kit. im looking to increase tire size and im looking to see if this size jump would work
    im currently running some 265 70 r17 i like my stock wheels but i am interested in purchasing some Nitto Trail Grapplers size LT285/70R17 E121/118Q these tires are about an inch and 3/4 taller than my old ones and im wondering will i get any rubbing?should i stick to the same size and just go that route. i would like some taller/wider tires but i dont want to get my MPG destroyed as well any help would be greatly appreciated thanks!
  2. Morpheus
    Morpheus New Member
    A lot of leveling kits and suspension lift kits will mention in the installation instructions what tires to run with the lift. With the Rough Country 2" level kit they advise a 285/70 for your year model truck.
  3. chihawks35
    i have the rough country thanks i think thats what im going to go with
  4. stchman
    A 285-70-17 will have an overall height of 32.71 inches, the 265-70-17 is 31.61 inches.
    That's a difference of 1.1 inches. They should not rub, but you will want to get the ECU updated to reflect the new tire size. Believe it or not, that will throw your automatic transmission shifting off.
  5. chihawks35
    The trail grapplers are actually 33 and some odd inches they have a little deeper tread which I think makes them taller. I've read some guides and it seems like as long as I have leveling kit I won't rub. Thanks for the input. As far as ecu goes I wouldn't even know where to start with that
  6. stchman
    You can get a tuner like Hypertech or Diablo. One of the options is to tell the ECU how tall the tire is in inches.
  7. chihawks35
    I'll have to look into that thanks
  8. TimTom64b
    Should not be a problem... I'm running that size without a leveling kit on my 2500.
  9. aloxdaddy99
    I have a level kit on my truck with 33's although mine are 12.50's and they rub a little. All I did was trim the inner fender skirt to remove what it was rubbing on. I think if you went with something like a 11.5 or so it may not rub.
  10. chihawks35
    yeah the ones i want are 11.57 thanks for the input
