Tire sizes, how big?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by ct9a, Aug 2, 2008.
  1. ct9a
    What's the biggest tire size I can fit on my 'burb without lifting it? I'm not opposed to doing a "little" bit of grinding either.
  2. MrShorty
    The standard answer for the OBS K1500's is about 33 inches (285x75R16).
  3. ct9a
    Thanks. What's OBS?
  4. retired2001
    "old body style"
  5. MrShorty
    As noted, it stands for "old body style" specifically referring to the '88-'98 style (which spills over into '99 and maybe 2000 model years in specific cases).
  6. ct9a
    Learn something new everyday. Thanks.
    Edit: Anyone know how much 33's will throw the speedometer off? Anyone know how to fix the speedometer on an OBD I?
  7. Pete95Sierra
    superlift makes a reprogrammer for it i believe. i ahd 33's on my truck and when i was going 70 on my speedo i was really goin 75
  8. retired2001
    Should be reading about 7.5% slow with the 33's, if I used the calculator right.
  9. ct9a
  10. zippy
    zippy Rockstar 100 Posts
    Checking around, the pundits proclaim: "No modification is necessary for tire sizes up to 265/75R16 (10x31.7). No modification is necessary for 285/75R16 (10x32.8) unless the wheel has a backspace of less than 4 1/2". Sizes larger than 285/75R16 require a lift kit."
    The backspace requirement indicates that wheel well rub is the first critical factor. There's always the possibility of a spacers before you start with a lift kit and different wheels.
