too much negative camber ?
Discussion in 'Lifted & Offroad Suspension' started by RATRODKING, Oct 29, 2009.
    RATRODKING Rockstar 100 Posts
    i have a stock suspensioned 1990 chevy k-1500 4x4 with factory wheels and 265-75-16 tires.
    about 6 months ago i had the pitman arm, idler arm, and sway bar links replaced, and they supposedly set the front alignment at that time. i was told i did not need tie rod ends or anything else. this is a trust worthy shop i have dealth with for a few years now. he could have told me i needed more, and i would have gone with it, but they said that is all i needed.
    before and after the alignment the tops of the front tires are noticeably pointing outward more than the bottom. this is neagative camber, correct ?
    the outside tread on my tires are wearing more than any other area on the front tires. is this a sign of a bad amilgment and the negative camber ?
    should i get it realigned ? it has been about 6k miles since i last rotated the tires.
    i want to get it right before i buy new tires.
    thanks much.
  2. Z71_guy
    have the alignment checked sounds like a issue
