torque converter
Discussion in 'Member Introductions' started by troysakis, Feb 22, 2010.
  1. troysakis
    troysakis New Member
    I recently put a 2,500 hughes converter in my 2000 silverado 4l60e 5.3. The first time i take off it will go through all the gears perfectly. When i come to a stop it will try to take off in 3rd. I can manually putt it in 2nd and take off. If i try and putt it in 1st it will not go it will stay in second. any ideas?
    TYMBOM Former Member
    My idea is that new members first post should be under the new members thread and be an intro. At least give an intro before trying to milk us for info. It's kinda like entering a conversation.
  3. troysakis
    Sorry not trying to "milk info" just new to this sort of thing. I'll give that a go first. Thanks
  4. Shorty 71
    Shorty 71 Epic Member 5+ Years ROTM Winner 1000 Posts
    Welcome to the site!! Sorry i can't help but look around and get a feel for the site, i'm sure someone can help you out and i'm sure you'll find alot of good info here.:glasses:
  5. Gambit
    Gambit Rockstar 100 Posts
    Did you put the torque converter in yourself or did a shop do it? If you did it your self did you fill it with ATF first? If not you may have burned it out before it even got broken in.
  6. Jimmiee
    The torque converter is not the problem. You need to scan it for codes. A VSS problem is likely or one of the shift solenoids is acting up. If you didn't get enough oil into the trans it would make the forward clutch slip and chatter and a big delay when going into gear. Double check all your connectors. Unplug them and look for bent pins. If it worked ok before then you did something during the R&R that's screwing it up.
  7. troysakis
    yeah its code is trans shift solinoid. and i have triple checked all my connections. even replaced solinoids. just running out of ideas.
  8. Eddie Z71
    Hi, and welcome to the site!:glasses:
  9. s5belford
    s5belford Epic Member 5+ Years 1000 Posts
    Welcome to the club!!!
  10. mmorgan1865
    mmorgan1865 Rockstar 4 Years 1000 Posts
    :sign0016: Sorry I can't help but I'm sure you'll find your answer here.
