torque wrench
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by 9191gmc, Oct 6, 2011.
  1. 9191gmc
    9191gmc Rockstar 100 Posts
    what is a good deal on a very decent torque wrench,ft pounds, right now...Craftsman or Snap on etc...
  2. silveradotrailblazer
    Get the Snap-On. More accurate and stays accurate. I like the clicker type.
  3. 9191gmc
    whats the best 1/2 inch torque adaptor out there???? they are cheaper..
  4. silveradotrailblazer
    Do you mean a torque multiplyer?
  5. SurrealOne
    Consider how many ft-lbs you need when buying one, as that'll impact price, too. A torque wrench that can do 80 ft-lbs is much cheaper than one that can do 150 ft-lbs. Also when choosing, consider that most of the time you should be torquing to 80% or less of the maximum capacity of the torque wrench. (If you're regularly doing 80 ft-lbs with a max 80 ft-lb torque wrench, you should move up to a 100 ft-lb torque wrench [or better] for that application.)
  6. 9191gmc
    I meant those digital adaptors that you can put on any good size breaker bar or long handle socket bar...do you think they are
    any good..??about 35 bucks
  7. silveradotrailblazer
    Buy the proper torque wrench needed for the job. If a bolt/nut calls for a specific torque setting than its important to do so and use the best torque wrench. I have one 1/2" drive torque wrench that goes from 50 to 250 ft.lbs , one 3/8" that goes from 20 to 100 ft. lbs. and one 3/8" that goes from 5 to 75 ft. lbs. All SnapOn. I send them back to SnapOn every couple of years to get recalibrated.
