Torsion Bars or Anti-sway bars
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by JungleJim, May 29, 2013.
  1. JungleJim
    JungleJim New Member
    I have a 2004 1500 burb that I lifted with a 3" SkyJacker suspension lift. It has alot of roll to it when travelling on country roads. I live in the Shenandoah Valley in Virginia and the roads are pretty curvy. I was wondering if there is an aftermarket solution to make it more stable. And BTW, what is the difference between torsion bars and anti sway bars?
  2. reggiecab2000
    reggiecab2000 Rockstar 4 Years 1000 Posts
    the torsion bar is part of your front suspension, you can tighten it to lift the front if your truck but itll make a rougher ride.
    anti sway bars are just that... they keep your vehicle from swaying during turns.
    solution:?
    1) replace all your rubber bushing with poly bushings (sway bar bushings, leaf spring bushings, body mount bushings, control arm bushings, etc.)
    2) add an anti sway bar to the rear of your suburban (hellwig, addco, etc.)
  3. Enkeiavalanche
    Enkeiavalanche Loving the Outdoors 4 Years ROTM Winner 5000 Posts
    As said above a Rear Anti Sway bar from Hellwig, Hotchkis , Addco and a few others will help alot You can get longer endlinks to work with them too..
  4. JungleJim
    Well, That helps me out!
    Thanks for the info.... It's niCe to get good answers when I'm an ignoramous about suCh things. BTW, the lower Case C doesn't work on my keyboard.
  5. tbplus10
    When the SkyJacker lift was installed were the factory Sway bar set-up reconnected?
    And did they use longer links or just rotate the swaybar up to connect?
    Could be as simple as correcting an issue created by the lift kit.
  6. Enkeiavalanche
    He might not have a rear factory Sway bar..
  7. tbplus10
    True but if they rotated the front sway bar itll agravate the situation.
    Its common to rotate the sway bar with many lift kits under 4", longer links are normally an option that most people dont understand the purpose of.
    The orientation of a sway bar is very important.
