Torsion key removal
Discussion in 'Chevy Truck Talk & GM News' started by 05DuramaxLLY, Apr 7, 2014.
  1. 05DuramaxLLY
    05DuramaxLLY New Member
    Hey everyone I know some people on here have put leveling kits on their trucks and I was wondering if anyone has had their torsion key's stuck on the torsion bar? I have run into that issue on my truck and I have gotten the passenger side off but the driver side is rusted on and doesn't want to budge. I have tried heating it and spraying it with some rust penetrating spray but yet its stuck still. I would remove the whole cross member but its riveted onto the frame. If anyone has any tips or tricks that could help I would greatly appreciate it because beating the crap out of it with a sledge hammer and pin just isn't doing the trick. Thanks
  2. rileyjr16
    *bump*****
  3. TimTom64b
    Air hammer worked on mine... not fun when they've had a few years to rust on.
  4. 05DuramaxLLY
    I actually tried that again tonight and still no luck. I've been soaking the torsion key in pb blaster and I have been trying to get the drivers side out since sunday. How bad would it be for me to cut a square out of the cross member to pull the whole torsion bar and key out to set it on the ground to get it off and weld the cross member back together? Cause i'm not seeing many other options.
  5. BRB46
    BRB46 Rockstar 100 Posts
    I wouldn't recommend cutting the crossmember. You would not want to weaken the structure. I had trouble with one of mine when I changed them. I ended up beating it out with rebar by driving the torsion rod out of the key using the crossmember as the stop for the key if that makes sense. You may already have been doing it that way. But that worked on mine. Also on reassembly I coated mine with a bit of red and tacky grease in case I need to remove them again.
  6. 05DuramaxLLY
    Well fantastic news everyone! Out of pure luck and some heat on the torsion key I FINALLY got the torsion bar out! I will be getting my shocks in tomorrow so ill post pictures up of the before and after the leveling kit. Thank you everyone for the help and I hope this post will help other people who are having the same issue I had.
