Torsion Keys...
Discussion in 'Lifted & Offroad Suspension' started by bigdaddy77084, Mar 17, 2010.
  1. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    I can see I have lots of adjustment left. So do I just tighten the bolts some more to raise the front end.. I just want a 1/2" or so & to level the front end out. The driver side is 1/4" higher than the other side.
    I have them soaking in WD/40 for a week.
  2. silveradotrailblazer
    torsion keys
    Its best to lift the front and take the weight off the front end when adjusting the keys. Yes just tighten them. Before you begin measure from the front wheel hub to the top of the fender on both sides and wright these measuements down so you have a record of were you started in case you want to go back down and also so you know how much you raised the truck.
  3. bigdaddy77084
    Thanks..You can look and see one bolt is in more than the other. I will put it up on jack stands. I dont want to lift it, just leveling the front end...Must of had a big girl riding
