Tow haul light
Discussion in 'General Chevy & GM Tech Questions' started by Ramdavis, Nov 9, 2011.
  1. Ramdavis
    Ramdavis New Member
    Tonight I went out for cofee and when I started the truck which is a 2006 silvy 4x4 crew cab with factory tow package, the tow haul light was on and would not go off by pressing the button. the truck was reving like it should when tow haul is engaged. I went inside for a cofee. When I started the truck again everything was normal. what would be causing this? Is there something getting ready to fail and is there anything that I can check?
  2. 99'HEARTBEAT
    I'm guessing what has happened is......there are Wire that run from the Tow Haul Button, down the Shifter and then down the Steering Column and at the base of the Steering Column, and overtime the Wires will sometimes get Pinched and/or Frayed.......below is a link with a Picture of the Wire and how to repair it......
    Starting on Reply Number #9,
    http://www.gmtruckclub.com/forum/showthread.php/30423-New-member-introduction-and-Tow-Haul-mode-prob.?highlight=haul broke
