Tow/Haul Mode
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by ChevyDan, Sep 27, 2009.
  1. ChevyDan
    ChevyDan New Member
    Hello, my truck has the tow/haul mode control on it and it stop working awhile ago. My Hayes book has nothing on this what so ever as I can find and cannot find a fuse or relay for it, just wondering if anyone else has run into this problem and what they had to do to get it working again. Thanks, Dan
  2. Jimmiee
    There is no relay or fuse Dan. The switch is just a momentary switch which sends a signal to the
    PCM. The switches do go bad and are very easy to diagnose. If you had a scanner you could just look at the data as you pushed the button. If no change is seen on the scanner the odds are the switch went open. Without a scanner you can just ground the wire at the switch. If the light comes on in the dash you have proved the switch is bad.
  3. ChevyDan
    ChevyDan New Member
    Hey Jim, thanks for the reply. No I do not a scanner yet but have been looking at some, want to get one in the near future. Will try the grounding thing and go from there, Thanks, Dan
  4. dorman68
    dorman68 New Member
    You need a new shift lever with a tow/haul switch. The same thing happened to my neighbor's truck.
