Towing?
Discussion in 'Chevy Colorado Forum (GMC Canyon)' started by Tapper1823, Apr 6, 2009.
  1. Tapper1823
    Tapper1823 Member
    Hey guys looking into getting a colorado/canyon with either the 3.5 or 3.7 crew cab 4x4. My question is how do these things do pulling bigger things? I would be pulling a decent sized fishing boat, and a crank downice house. Thanks! :great:
  2. TRPLXL2
    My buddy has a 2004 Colorado 3.5 I-5. extended cab 2wd, and he pulls a small boat (14 foot) from Ohio to West Virginia every year a couple times. The only thin he ever said was the shifting up and down in the hills, he said it will constantly shift up and down until the ground levels out even. He said it has plenty of power and torque, but the shift points are kind of screwed up when towing. He is actually looking at buying a programmer to try and correct the shift points, so other than that it is a great little truck for towing small things.
  3. Tapper1823
    Tapper1823 Member
    Yeah I would like something I don't have to up/down shift a lot. So if that is the case I will get a 07 or 08 Silverado. Thanks for the reply. Anyone else have any input?
  4. tlperry68
    Well its all weight proportional. A colorado has a much lighter payload capacity than the silverado. If your boat & trailer combo weighs around 80 or 90 % capacity for the colorado you might be better off with the silverado.
    Also there is a price difference but the 1500 is not a whole lot more than the colorado.
    Good luck.
  5. s10tower
    s10tower New Member
    looking at new truck?
    Hello, new at posting at forum, just looking at information from people that actually use these truck on daily basics, I have an s10 that getting old and a couple of trailer that have some weight i have a 21 foot camper and 28 foot car hauler, and I like to stay with the mini truck/mid size truck. the most I tow is 5000lbs and 400 lbs pin weight(it a small low profile fifthwheel) It tows like a dream just wondering if would be okay with a colorado with the v8, and any information would be great.
    thanks s10tower
  6. TRPLXL2
    Well that Colorado with the 5.3 V-8 would be like a mini Silverado, I would say with a crew cab version with the 4.10 gears it might handle it but I have never driven one so I can't say for sure. That 5.3 is the same one that's in the Silverado, so the horsepower is there.
  7. Greg84
    Greg84 Rockstar 100 Posts
    You pull a 5th wheel trailer with an S10?! :eek:
  8. s10tower
    s10tower New Member
    Yes I tow a small fifthwheel with my S10, It tow great too!!:great:it got 4.3L v6 with automatic with 3.42 gears in the rear end with. It will not go past 130km/h but it sure does A great job flying down the highway.
  9. cmcoram
    cmcoram New Member
    It's not the shift points, its the fact the tranny is 4-speed. The 4th gear is "Overdrive." Tell your buddy to shift it to 3rd, and he should see a significant decrease in the shifting. I drove mine from NC to OK last summer, and had no problems.
  10. Lew
    Lew New Member
    Towing vs Stopping
    It's not the towing that is the problem, it's stopping the whole shebang. You start getting up to max tow weight, better make sure you have trailer brakes or you could go sliding through an intersection with brakes locked.
