Trailer Wiring Harness
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Huntr, Dec 6, 2010.
  1. Huntr
    Huntr Rockstar
    1997 Suburban
    Is this a factory trailer wiring harness?
    I've never seen one like it. Will a standard 4-flat plug fit it? What is the row of 4 round plugs for? Do I need some sort of adapter?
  2. Crawdaddy
    Crawdaddy has no brakes Staff Member 5+ Years 1000 Posts Platinum Contributor
    It's not factory, it's definitely addon. Usually the double-stacked sockets like that have provisions for the 4-flat and 5-flat trailer connectors, but it doesn't appear that's the case with yours. Regardless, not factory. The factory one would be most likely a 7-way installed in the bumper.
  3. Huntr
    Huntr Rockstar
    Thank you.
  4. murdog94
    X2, they do offer a flat 4 that was factory, but it was basic.
  5. Huntr
    Huntr Rockstar
    I cleaned it up and in doing so, I was able to see where it is labeled U-Haul. The 2nd set of holes is for their proprietary wirning harnesses. Plug works just fine.
  6. Crawdaddy
    Good to know you figured it out. U-Haul has used some weird proprietary trailer harnesses over the years, but they finally came to their senses and swapped everything over to the industry-standard flat-4.
  7. Huntr
    Huntr Rockstar
    Thank goodness. Their wirning harness adapters were a pain in the butt.
  8. Huntr
    Huntr Rockstar
    My scout troop is looking to upgrade to a double axle trailer w/brakes. I have the factory tow package on my 1997 Suburban 1500. I understand from reading on here that the factory trailer wiring harness ends at the bumper, and then a trailer harness is plugged into it. Is this correct? Does the factory wiring harness have the connections for a 7 way plug?
