  1. Chevy Truck Forum
    Welcome To GMTruckClub.com!
    Online since 2004, we're the #1 Chevy Truck & SUV user community. If you have any questions about your Chevy or GMC Truck, SUV or Crossover, or just want to connect with other GM owners and enthusiasts around the world, you've found the best place on the internet to do that.
    Join Today ~ It's Free
    Registering is Free and Easy! Do it today and we'll see you on the forums soon!
Tranny issue with 1996 silverado
Discussion in 'GM Powertrain' started by 96BlackSilverado, Mar 15, 2010.
  1. 96BlackSilverado
    96BlackSilverado New Member
    i have a 96 silverado 4x4 with the 5.7 The transmission will sometimes come out of overdrive on the highway when Im barely on the gas. It doesnt seem to downshift all the way it kind of shifts down and then right back up. Any ideas what this could be?
  2. ejohnson03
    ejohnson03 Epic Member 5+ Years 1000 Posts
    When I first got my '94 pickup last year (174,000 miles), it seemed to do the same thing. And it was really annoying.
    Not real sure what it was, 'cuz I changed everything on the motor. Tossed out the worn out factory motor and slid in a rebuild and gave a little muscle.:gasp:
    The tranny I left alone, except for adding some Lucas Trans additive.
    Now it runs down the road smoothly and effortlessly...
    Good luck...
  3. tommyboy
    tommyboy Member
    Mine was shifting strange a couple of weeks ago and it ended up being a blown fuse. The fuse box under the hood drivers side has a fuse that controls your transmission. On my 98 it was labelled as engine ??(something) I think it was a 20 amp fuse. I replaced it and been shifting smooth ever since.
    Hope this helps. Good luck
  4. doug_scott
    doug_scott Rockstar
    It will come out of lockup ( that is what you are seeing, not downshifting into a lower gear) if you release the gas or touch the brakes as well. Try it, just touch the brakes while cruising along at 60mph, the tach will immedietely go up a couple of hundred rpm. It is just the torque convertor unlocking.
  5. Jimmiee
    That's exactly right Doug. It's the converter. What's probably happening is the TCC regulator valve is worn out inside the valve body. Get the truck scanned for codes. You probably have a slip code stored in memory.
