    Join Today ~ It's Free
Tranny Problems
Discussion in 'GM Powertrain' started by Larryuidiot, Jan 19, 2010.
  1. Larryuidiot
    Larryuidiot New Member
    My son has a 2001 S-10.Has the 4-cyl engine with the automatic tranny.Says it is acting up on the highway.It will run fine then all of a sudden it will come out of overdrive and downshift and the only way he can get it to go back in overdrive is to stop and start over again.Does this 2 or 3 times when he is out on the highway.Fluid is full and clean.Any suggestions?
  2. Velocity1
    Velocity1 Rockstar
    Depending on transmission type/model, It may be that the upshift/downshift spool valve is malfunctioning. Causes of this vary from old age and wear, (binding valve or low apply pressure), Intermittent electrical apply solenoid, to possibly a governor malfunction. You might also check the TV cable adjustment. This is potentially cured through adjustments repairs made by dropping the pan by a qualified technician familiar with your particular trans. I'd invest in correcting the problem now as it will only get worse to the point of failure.
    Good luck.
