Tranny temp gauge
Discussion in 'General Chevy & GM Tech Questions' started by farmermike, Sep 8, 2009.
  1. farmermike
    farmermike New Member
    I would like a tranny temp gauge. There is a blank on the lower left side of cluster, would it go there ? Would I need a whole new cluster? Is the wiring in the harness? Where could I order what I need ?
    Thanks, Mike
  2. farmermike
    It's an 04 Z71, 5.3 with DIC. I'll try to add this info to my sig.
  3. 99'HEARTBEAT
    Yes you can get a Dash Cluster that has the Transmission Gauge......the 99" to 07" GMT-800 NBS Silverado/Sierra's 1/2 Ton's were/are Pre-Wired from the Factory for the Trans Temp Gauge,
    You can Buy an Escalade or Denali Dash Cluster, as they come from the Factory with the Transmission Temp Gauge in their Dash Cluster's, and the Best place/pricing is on E-Bay.
    One last note is that if you do get a New Cluster it will need to be Reprogrammed for the Current Mileage on your Truck.
  4. farmermike
    Is it possible to add just the gauge ? Also is there a sending unit to add to the tranny?
  5. sc99z71
    sc99z71 Rockstar 100 Posts
    I am interested in this also, is it really that simple as buying acluster with the trans temp gauge in it?
  6. 99'HEARTBEAT
    Yes, Its that Simple, as I mentioned, in my Reply above......Here is the Escalade Dash Cluster that's in my Silverado,
    [​IMG]
  7. 99'HEARTBEAT
    I have seen it done.....I can not find the Thread right now.....
  8. sc99z71
    SWEET!!! Will look at ebay when I get home, can't here at work. Looks like that is my next project!!!
  9. sc99z71
    Does the dealer reprogram the mileage? Do you take it to them pre-install or after its in?
  10. 99'HEARTBEAT
    Some Dealers will Re-Program for the Mileage, and Some Won't.....
    I had mind Programmed at a Local Speed Shop....There are a few Company's on the E-Bay, that do the Re-Programming.
