Trans fluid cooler
Discussion in 'GM Powertrain' started by rileyjr16, Aug 27, 2013.
  1. rileyjr16
    Looking into doing a transmission fluid cooler mod here soon like maybe late September early October.
    Definitely going to put in an oversized cooler probably an electric fan to help cool it off when it's really hot outside. Finding kits on eBay for 30$-40$ for just the unit with no fan. Just no clue as to what size or brand I should go with. Also looking into doing an electric fan mod on the radiator too later on.
    Just looking for input on the size and brand of the cooler I should use
    or be comfortable spending money on.
  2. vncj96
    I cant imagine there is room for a fan that is solely for the tranny cooler, never even heard of that, they just get mounted to the front side of the radiator. Unless your towing something ungodly big for your truck and driving like a maniac a factory tranny cooler is just fine. You could probably pick up all the parts needed to add IF you don't already have a factory cooler, pretty cheap at a good salvage yard. they are only about 12" x 12" and are easy to spot. As far as adding an electric fan in place of the engine driven fan, you have lots of options. You can buy a prefab kit or look in the write up section and see how to wire it yourself using a Ford Taures 3.8 radiator dual fan.
  3. CKNSLS
    CKNSLS Rockstar 100 Posts
  4. mfleetwood
    I agree about the fan...and in fact, my factory cooler was sufficient for normal driving, like vncj96 and CKNLS mention, but I will also add that if/when after you install your lift and you get substantially taller tires and not re-gear, it will also drive up tranny temp.
    When I needed to go to an after-market tranny cooler is when I put on the ~35" tires and going off-road or up paved hills in the mountains and my tranny temp sky-rocketed (and this was after I re-geared). After I swapped my factory cooler to the Tru-Cool 40k tranny cooler, I'm back to running great tranny temps and still no fan needed.
    Here is a thread that details the Tru-Cool 40k cooler....check out what members have to say; it may be an option for you.
    http://www.gmtruckclub.com/forum/showthread.php/88250-New-Transmission-Cooler?highlight=cool
  5. rileyjr16
    I most likely won't be lifting it. But being in Virginia I run into a lot of stop and go traffic trying to get on base. The trans has 235,000 on it already. When Katelyn moves up, chances are ill be doing some mountain driving in western Virginia going camping. And if I have get orders to the west coast or somewhere else, I'll be towing a trailer loaded down with furniture and all. Electric fans are a for sure thing. Might look into the dual Taurus fans
  6. mfleetwood
    Oh,sorry. I was going by your list of future mods. Just of of curiosity, how hot is your tranny temp running now with your normal driving?
  7. rileyjr16
    Don't know since I don't have a gauge for it. I'm taking another 2,200 round trip here in a few weeks to Mississippi and I've always just wanted a bigger one for potentially long trips or pullin the boat.
  8. mfleetwood
    Wow, long road trip! And with that type of use, you should be fine with just adding an OEM type of tranny cooler. It'll fit in there really nice. Also, you may want to check with some of other members here to see if anyone still has their stock cooler that may want to get rid of, as many of us here went to the Tru-Cool. If so, they may sell it to you cheap or give it to you. I ended up giving away my stock cooler to a member on this site after I changed mine out as I really didn't have a need for it any longer.
  9. CKNSLS
    The OEM tranny cooler on my truck-2011 Silverado Crew Cab /5.3 is a joke. It's the size of a large paperback novel. It is barely adequate. He needs something a little better.
  10. mfleetwood
    I agree, they really are for lightweight towing (or other stressors) as that's why I changed mine out and initially recommended the tru cool to Riley to begin with. However, if it's relatively light towing at this time and he can pick one up for free and it will bolt right in, it might be another viable option for him or anyone else to consider. A tru cool and mounting kit will run about $200.
