Trans leak 99 2 door Tahoe
Discussion in 'GM Powertrain' started by Surf911S, Sep 2, 2009.
  1. Surf911S
    Surf911S New Member
    Went to drive the hoe to work today. Pulled it out of the garage to dust her off, and as I was walking into the garage to get the duster, I find red fluid on the gargae floor. Squeezing my head between the frame and concrete floor, I see tranny fluid covering the knuckle that connects the rear of the tranny to the drive line.
    I guess its safe to say the rear seal needs replacing ? No leaks anywere else but the knuckle.
  2. Jimmiee
    Take a close look to see if the seal is leaking or if the fluid is coming out of the center of the yoke. If there is a hole in the center of the yoke and fluid coming out there then you need to replace the o ring which requires removing the tail shaft housing. If there is no hole there then the rear seal is leaking.
  3. Surf911S
    Surf911S New Member
    Thanks Jim.
