transfer case ID?
Discussion in 'General Chevy & GM Tech Questions' started by desertjoe, May 19, 2010.
  1. desertjoe
    desertjoe New Member
    Hello Neighbors,,, I need to borrow somebody's knowledge. I have a 1980 k10 350/ 350 that I can't seem to be able to ID the transfer case. According to my Haynes manual the 80 X-fer case used 85-90Wt and the 81's and later used Dexron 2. Also the manual tells me there is a tag that ID's the X-fer case,,,,,but I can't find no tag. I did find some #'s on the back of case as follows. AE C-99404-1 N. What is kinda throwing me is that when checking the fluid level,,,it was full and I mean full of Dexron 2. Did PO swap X-fer cases or ? Boy, you just never know about these old trucks,huh? Can fluid from tranny migrate into X-fer case? I need to ID this thing to make sure it has the right fluid. Looks like I am going to have to pull the X-fer case as there is a slight leak at both the output shafts. One more question,,,,Is the transfer case from a standard transmission same as from an auto? Many thanks Joe r
  2. desertjoe
    Hey Guys,, I really need some help here. I need some help to ID my transfer case. My haynes manual says the 80 and earlier TC use 85-90 while the 81's and later use Dexron 2. Can anybody help? Thanks
  3. Vinniety
    Vinniety New Member
