Transfer Case Leaking
Discussion in 'Member Introductions' started by bak22, May 2, 2010.
  1. bak22
    bak22 New Member
    Was wondering if anyone has come across this issue. I have an '03 Z71 with 125K. No issues to date, until I noticed a few fluid spots in the garage. The T-Case is leaking from what appears to be the separation line of the two halves. Passenger side bolts just above the fill plug area is where I keep noticing the fluid build up. The input & output seal areas look good. Anyone ever have this issue & what was the solution? Thanks.
  2. 2COR517
    Is it the two halves of the transfer case? If so, you are going to have to remove it and split the case. Re-seal it with Permatex Black or Gray.
    If it's the connection between the t-case and trans, you will still have to pull the case. You can put a new gasket in, or RTV.
    1 person likes this.
  3. murdog94
    And now you know why on my 22 year old truck i just add more fluid... :lol:
  4. Eddie Z71
    Hi, and welcome to the site!:glasses:
  5. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    I would try some Lucas stop leak first. Check the vent tube to make sure its not kinked or pluged..
