Transmission Fluid/Filter 2003 Suburban 2500 6.0L
Discussion in 'GM Powertrain' started by meash20, Mar 19, 2009.
  1. meash20
    meash20 Rockstar
    I'm planning on changing the Filter and Fluid in my 03 'Burban.... Any gotchas I should know about before I start?
    The tranny does have a drain plug which seems helpful... Just looking for some input before I get started!
    thanks,
    -matt-
  2. Jimmiee
    It's a straight forward job Matt. Make sure you have a big drain pan cause it can get messy. Leave a couple of bolts finger tight in the back and pry the front loose if it's stuck. Make sure to use a good pan gasket and fill it to the add mark. Road test it and get it hot before adding any more fluid as you don't want it over the full / hot mark.
    Jim
  3. meash20
    meash20 Rockstar
    Cool, yeah everything I've read, seen makes it look pretty straight forward.
    Follow-Up Question: The truck has 158K miles on it... any value in using a synthetic ATF ?
    -matt-
  4. 1st Synthetics
    Using synthetic fluids is always a great idea, This is a fact. I'm not saying it because I sell it.
    CAPACITIES
    5.3L
    Automatic Transmission, 4L80-E Initial Fill..........7.7 quarts
    Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
    Automatic Transmission, Total Fill
    4 speed 4L80-E..........14.0 quarts
    4 speed 4L60-E..........11.0 quarts
    6.0L & 8.0L
    Automatic Transmission, 4L85-E Initial Fill..........7.7 quarts
    4 speed 4L85-E..........14.0 quarts
