Transmission Flush
Discussion in 'General Chevy & GM Tech Questions' started by bzboardco, Jan 14, 2009.
  1. bzboardco
    bzboardco Rockstar 100 Posts
    I have read a thread on here and some other forums and it seems that it is about 50/50 for it and against it. My truck has 120,000 miles on it so I am thinking I need to make the choice...btw it has never been done on it before. What do you guys think :neutral:
  2. 04sierracrewcab
    You are correct you will get many diffrent ansers.
    I will prolly flush mine around 75,000 and then at 50k intervals.
    I would say go for it. :great:
    After all it cant hurt anything!:money:
  3. heaviechevie
    heaviechevie Member
    I was always told it was ok to do it if it had been done once before. If it's over 90,0000 miles and doing it for the first time not to. But I never listened. I think you might be ok if the fluid isn't really burnt. I did mine and as far as I know it wasn't ever done and I have around 190,000 miles.
  4. retired
    retired Rockstar 100 Posts
    I was in the transmission business for years, here is what could happen if you change your fluid with that kind of mileage on it. The trans will start slipping or just stop working all together. And here is the reason why, new trans fluid has a mild detergent in it, it will basically clean all the friction material off of the clutch packs and steals. I have seen this done many of times so if you want to make your tranny guy happy go ahead and change it.
  5. werty
    werty Rockstar 100 Posts
    I did the 93 z71 at 203000.......last summer granted it was just the fluid in the pan and the filter....shes strong as ever now
    so i guess its a touch and go situation
  6. bzboardco
    Knocking on wood real hard!
    Luckily I have been fortunate with this truck. I change the oil religiously and I also change the air filter and fuel filter. This truck still has the same plugs and wires from the factory. So I am trying to knock out all the maintenance that I have been putting off. The truck runs perfect. I just know they need to get done.
