Transmission Impossible: Filter Seal is fused with trans!
Discussion in 'GM Powertrain' started by BlackJack1500, Nov 22, 2010.
  1. BlackJack1500
    BlackJack1500 Rockstar
    I have a 06 Silverado 4.8L with 76,000 miles and I can't get the trans filter seal out. It has 16 bolt pan so I think it is the 4L60e. I have tried pliers, screwdrivers "phillps, flat head, cureved, straight , etc" and it will not move. I finally gave up and left the old seal in there but not before a piece of the rubber seal got scratched off. Is there an easy way that I don't know of to get this thing out? Did I do the wrong thing by leaving the old one in there? The new filter went in fine and feels secure. Bolted everything up and 1,000 miles later still seems to be shifting ok although the trans feels like it hangs up a little on the 2nd to 3rd shift. But that is only before its warmed up then it shifts fine. I am new to the site so hope I am not posting too early. I tried looking up with the search but could not find an exact problem like mine. Thanks for the help guys.
  2. stephan
    Hey Rusty, I've never taken a filter off the 4L60E but from what people here have said it is just a remade electrical version of the 700R4. Is your filter tube round & approx 3/4"-1" diameter with an o ring for sealing up into the trans inlet bore? If so don't worry about using 2 orings in there. I have used 2 o rings (sometimes 3) for several years in my 700R4 just to make the filter more secure so it isn't flopping around. The damn filter can flip & flop around like a fish out of water with only 1 o ring & there really isn't any way to make it more secure other than adding o rings to it. If that's what you did, you're fine.
  3. BlackJack1500
    Hey Stephan,
    Thanks for the advice. I looked up the 700r4 filter and the 4l60e and they look the same especially the tubes. I think your idea will work but I still have to get the old one out to have room for the orings. The seal in the 4l60e is more like a 1 inch long metal bushing with a hard plastic or rubber coating and doesn't flex like an oring. When I put the new filter in it was kinda of floppy like you said but not too bad so hopefully it wont move. Guess I will leave it for now and hope nothing bad happens. BTW good luck with all the snow yall are having up there. I have never driven in snow but doesn't sound fun. LOL!
    LAter man.
  4. stephan
    So this is not the O ring seal that you're talking about? I thought you had the old O ring stuck in the bore..
    Here is a Picture of a.....4L60e......Is the part your talking about the middle of the picture??......
    If the New Transmission Filter did not have a Snug fit after installing it in to the ......Transmission Filter Seal....the Trans.Filter overtime may work its way out of the Seal.....??
  6. stephan
    Hey Mike, in your pic if you disregard the dust cap in the middle & look around the rough edges from 11 oclock around to 2 oclock it looks like that is the tube of a filter broken off in the bore. Is that what I'm seeing?
  7. webf2010
    webf2010 New Member
    How did this happened, I think you have to change the part.
    Stephan.....That is a Picture from A Link, On doing a Transmission Service on a 4L60e......I wasn't able to pull the whole link last night.....
    In the picture.....the person is showing one of the ways to remove the ....Transmission Filter using a screwdriver and Carefully bent the metal part of the Seal Inward....Once he was able to bent it far enough, he was able to get a pair of safety wire pliers on it & pull it out....and careful Not to nick the aluminum housing on the Transmission,
    ....Below is the whole link with a Write-up and pictures,.....on Servicing the 4L60e Transmission,
  9. silveradotrailblazer
    What '99Heartbeat showed is how I've changed my filter seal. A small screwdriver tapped in one side with a hammer and then pulled out with a pair of needle nose pliers. When installing the new seal I put the seal on the rounded end of a ball-peen hammer and press into place.
  10. stephan
    OK Thanks Mike
