Transmission issues 82 elcomino
Discussion in 'GM Powertrain' started by mralers86, May 12, 2010.
  1. mralers86
    mralers86 New Member
    I have a 82 elcomino that has a 350 chevy truck motor (one belt, if that matters). im not sure wat year n model the motor is i jus no its between 78-89. My transmission will go in R but not D so i figure is pretty much over for that trans. Im wondering what transmission i need and i was wondering if there are any online sites that are suggested.
  2. bigdaddy77084
    bigdaddy77084 Epic Member 5+ Years 500 Posts
    Does it have a carb??
  3. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    Didnt they come with the old Turbo 350 trannys?
  4. bigdaddy77084
    im thinking the short one.. And if it has a carb the tranny is all vacuum. I know if you dont hook that vacuum line up in the right place the tranny will shift funny or not at all..
  5. rustyk2
    rustyk2 Rockstar 4 Years 500 Posts
    Most El Camino's came with a th350 vacuum modulated transmission.
  6. murdog94
    And if it is an OD it is a 200R4....
  7. mralers86
    it has a 650 elderbrock
  8. mralers86
    it has a 650 eldebrock on it. b4 the trans went out the shifting was a little funny and i could never get it rite. i assumed it was my kick dwn cable n i adjusted it the best i could, so that da shift wasnt bad but it wasnt on point (if that make sense). i got up one morning put it in D went to pull off and sumthing popped. so wit me not knowing the yr this motor is, i dont know what transmission to shop for and the local ppl want to charge a arm and a leg jus to check it out.
  9. rustyk2
    can you check the casting numbers on the block? they should be stamped in on a flat surface. Then check on line, there are sites to find what year the block was manufactured.
  10. bigdaddy77084
    try your luck at a junk yard..A tranny job aint that hard..
