Transmission Issues
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by allwheelspin, Nov 8, 2009.
  1. allwheelspin
    allwheelspin New Member
    Hello, For about a month or so now my transmission has been acting weird. In 3rd gear and in OD it will flare up a couple hundred RPM's and than come back down to the normal RPM. This happens most of the time while driving now. Only occurs when going between 40MPH (OD engages) and 60MPH. Any ideas? 00 Silverado 5.3 185,XXX Fluid changed / filter last year. Thanks.
  2. Jimmiee
    Welcome to GMTC. You first step is get the truck checked for trouble codes. You may have a torque converter problem or it could be the 4th gear band. Checking the codes will pinpoint the problem.
  3. LivysMan
    LivysMan Member
    check your fluid level!! mine did alot like that!!
