Transmission Oil-FilterChange-1990 Cheyenne-1500
Discussion in 'GM Powertrain' started by Air Force One, Jan 27, 2009.
  1. Air Force One
    Air Force One New Member
    {1990 Cheyenne-1500/305 V-8/Four Speed Auto with Over Drive} > When I drop the Transmission pan its covered by a crossbeam member (Four bolts), and in the middle there is another bolt that holds up the end of the transmission with a rubber vibration pad in between the crossbeam member. To get to the bolts on the end of Transmission pan I have to remove these five bolts. QUESTION: do I need to be aware of anything prior to doing this as its all new to me? Thanks in advance...AF1
  2. Crawdaddy
    Well, for starters, you need a jackstand to hold the tailshaft of the transmission up when you drop the crossmember, because that's the only thing holding the back of the transmission up. Take a block of wood and put it between the jack and the pan and pick it up a hair. Then you can loosen and remove the crossmember. Then lower the tailshaft onto a jackstand and you should be able to remove the jack if you did it right. Then you have half a billion bolts to pull on the pan and you're home free. Make sure you have all the parts.
  3. Air Force One
    1990 Transmission Oil Change-Question #2
    Thanks Chris~ After looking at the Cross Beam Member it only goes under the Pan, not holding it up. Looks like I can take this off without any support, then put a jack under tail shaft section to hold it up. Am I looking at something wrong here? Thanks again
  4. Crawdaddy
    You are correct, the crossmember is not holding the pan up, but like I'm sure you saw, it's blocking access to bolts for the pan. However, that crossmember is holding up the entire transmission, so you have to support the trasmission while you pull the crossmember and the pan just happens to be a good spot to do so until you can support the tailshaft. I know it sounds stupid, but don't try to support from the tailshaft straight out...
  5. Air Force One
    Appreciate it Chris..I was just concerned about putting a jack under the pan, and possibly denting etc it up. I follow what you say! Its a next job Sat for sure. AF1
  6. werty
    werty Rockstar 100 Posts
    is that thing still shifting funny???
  7. Air Force One
    Yep! Still shifting hard going from 1st to 2nd and 3rd. When it warms up it runs smooth.
  8. Crawdaddy
    Just remember what I said and use a board between your floor jack an the pan, like a 2X4 2 foot long or so. 2x6s or 2x8 would be even better if you have them floating around. Just whatever you do DO NOT LIFT FROM THE PAN DIRECTLY WITH THE JACK. USE A BOARD BETWEEN THE JACK AND THE PAN. Ok, enough shouting.... I just don't want to see you bend the pan... :great:
