Transmission slipping and I need your help please
Discussion in 'GM Powertrain' started by b_burdine, Dec 25, 2009.
  1. b_burdine
    b_burdine Rockstar 100 Posts
    If a transmission slips, does that mean it is completely messed up? If not, what can I do to get it fixed? Would getting a complete transmission fluid flush work? Anything will help!
    If my transmission is done what would you all recommend to replace it?
  2. azdrtdog
    azdrtdog Epic Member 5+ Years 100 Posts
    Cold weather makes alot of tired autos start to slip because the seals get stiff from heat try some seal reconditioner and see if that gets ya down the road another winter
  3. Jimmiee
    Did you get it scanned for codes? When a transmission slips it's either because the clutch pack is shot and if so the transmission will need internal work, or, in some cases on electronically controlled transmissions the Pressure control Solenoid is malfunctioning. The trouble codes will tell the tale.
  4. sruss
    sruss New Member
    Both of them are right, but check your fluid level first and look at the color of the fluid. It could need to be changed, it will slip if its low or if the fluid is too old. Try that first, then go for the seal reconditioner, depending on the mileage, you might want to throw some in anyway.
  5. Stealth
    i think i will have my local shop try that on mine, it slips occasionaly when going into or out of reverse with some throttle applicaiton
  6. azdrtdog
    I hate to admit it but i have had some great results using the bottled fixes.I had a 2000 f250 work truck that had a swamp in the rad.brown and stunk i put in antifreeze restore and the dam stuff turned it bright green and no longer stunk! my friend pushed out a head gasket on a buick with a 5.0 sbc.we used some block ceramic that u put in after you flush with clean water and it sealed he is still driving it after 4 months
  7. mountaindan
    mountaindan New Member
    I'm guilty also of using bottled fixes! Try some lucas transmission fix, I was having slipping and hard shifting, dumped a bottle in about a year ago, so far so good.
