Transmission Went BOOM!!
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Huntr, Jan 27, 2011.
  1. Huntr
    Huntr Rockstar
    1997 K1500 Suburban
    Something is not quite right here...
    Picture taken with cell phone from passenger side. Rear of transmission, before the transfer case.
    Anybody have any thoughts on what would cause the failure?
  2. silveradotrailblazer
    DAMN ! How many miles on the trans?
  3. Huntr
    Huntr Rockstar
    Only about 350 since a rebuild. Guy that did the rebuild is gonna come get it tomorrow to figure out what the heck happened.
  4. ntbush83
    That is crazy! Sorry I have no clue! But thanks for the pic! Sorry bout your luck!
    HOLY F%@#.....:gasp:......Sorry to see something like that.....Good Luck.
  6. tbplus10
    When they fail it usually isnt that catastophic, be interesting to hear what went wrong.
  7. stephan
    The last one that I saw that was that bad, no one could determine what went wrong. The best guess was that something caused it to try & select two gears at once, or that there had been a small piece that broke off & wedged between two gears at once causing failure, but nobody ever knew for sure.....
  8. dsfloyd
    d@mn! sorry to hear (and see) that.
  9. Chris Miller
    Looks like something just broke off inside and tore through the case, not unlike snapping a rod off in an engine and punching it through the block.
  10. Crawdaddy
    If I had to guess where on the transmission that picture was taken, I'd have to guess that's where the transfer case bolts onto the tailshaft extension housing. I have no idea how there would be that much stress on that part unless you got the whole truck stuck on a rock right around where the hole is. There shouldn't be any torsional force in that region to cause the case to get stressed and fail like that. The good news is that a replacement tailshaft housing should be pretty easy to find in a junkyard, shouldn't cost a ton, and should be pretty easy to remove and replace. The big question is what caused all the stress at that part to cause it to happen.
